03-06-2022
07:06
20:21
03-06-2022
07:06
20:21
I got a Versa 3 for Christmas and it has worked great until about 4 days ago. It does not sync and when I look on Bluetooth, the device is not listed. I have looked thru this forum and turned in/off Bluetooth, my phone, ensured all
is charged, wifi is good etc.. this is incredibly frustrating. I’ve had previous Fitbits and never had this problem. Was going to call Fitbit for a replacement but thought I would try here first. Advice anyone? Sounds like this has been an issue for a few…
03-06-2022 08:16
03-06-2022 08:16
Hi @Nala3 - just because you don't see the Bluetooth entry doesn't mean it's not there and it doesn't use Wifi, so that can be excluded as a thing to check.
if not look here Why won't my Fitbit device sync?
Best Answer03-06-2022 10:13
03-06-2022 10:13
Thanks! Ended up doing the whole restart and it worked. Incredibly frustrating as never had any issues until recently. Hopefully last time (fingers crossed). Thanks again.
