09-19-2021
12:31
20:43
09-19-2021
12:31
20:43
I have bought my Versa 3 a few months, just trying to use the GPS, but it keep showing GPS connecting.....,
I have tried the online help, tried restarting my watch, tried restore my watch yo factory reset. Nothing is working. The terrible thing is I bought my watch online, so cant even go to the store to ask! And no email support system!
Maybe its time to quit the Fitbit!!
09-20-2021 07:10
09-20-2021 07:10
Hi there, @Yantu. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. We‘re taking your comments and sentiments in regards to our products and services into consideration.
Please note that if you're in a new location farther away from where you normally run, it may take a few minutes to connect.
With that being said, I'd like to know if you've recently changed your normally location? How long do you wait for the GPS signal to connect? If you've noticed it's less than 5 minutes, please let your watch try to connect for at least 5 minutes before cancelling the exercise. Your Versa 3 will continue to try connecting and you can go about your run.
Also, please make sure your Versa 3 meets the requirements for connecting to GPS. For more information, see Why isn't GPS working on my Fitbit device?
Moreover, please be advised that environmental factors, including tall buildings, dense forest, steep hills, and thick cloud cover, can interfere with your device’s ability to connect to GPS satellites. If the signal is blocked—either because you're indoors, underground, or due to another reason—GPS won't work.
Hope this helps.
Best Answer09-20-2021 07:10
09-20-2021 07:10
Hope this helps.
Best Answer05-20-2022 14:50
05-20-2022 14:50
Tried the 5m wait.
Tried with my phone right beside.
Tried factory reset.
At home where I've connected before. No tall buildings, nothing.
GPS doesn't connect.
Any ideas as to what to try?
