03-14-2023 11:09
03-14-2023 11:09
I’ve just recently started having a problem with my treadmill and Versa 3 having completely different mileage. Some days it’s not too far off but other days it can be as much as 5 miles difference. I have always used the hand rails on the treadmill so I don’t think that’s the problem. It’s just really frustrating. Any suggestions?
03-15-2023
12:57
09:52
03-15-2023
12:57
09:52
@achurch , A warm welcome to the Community ! Thank you for your message.
Distance is calculated by multiplying the amount of steps x your stride length.
You mentioned that you use the handrails while running. This can cause that some of your steps do not get recognized. So that the distance gets another measurement.
Have you verified if the amount of steps on the days that the distance doesn't match, is similar ?
