09-17-2022
15:47
17:12
09-17-2022
15:47
17:12
After using Timers (primarily Countdown rather than Stopwatch) on my Fitbit Versa 3 for several months, I tried to set a timer the other day, and when I opened the App, I see the following message:
Timers list is full. Please remove existing times first to add more.
I cannot find anywhere I can list/edit/delete the stored timers on the Fitbit, or my iPhone, or on a PC (nor can I find any related instructions for doing so). Is there a means to find and edit this list, or is my Versa 3 no longer capable of using the Timer function (that would be a BIG problem). Generally I'm very pleased with my Versa 3, though not a big fan of the single 'button'. Any help/direction would be much appreciated.
Hi @Behappy2 - first try restarting the watch.
The message you see on the watch seems to be coming from the the Timers app.
The documentation isn't brilliant and you are limited to a maximum of 3 timers before the message appears (when trying to add a fourth).
To fix it, start the Timers app
Do that for any existing timers, then you should be able to add a new timer.
When it reaches the end it should clear by itself, but if you pause it the timer will stay.
If you can't resolve it have a look at timer apps in the gallery, such as SimpleTimer it has extra features, like 4 presets and remembers the last timer and has auto start but needs to be the running app during timing unless you are using the SimpleClockPro watch face.
