01-05-2021
03:30
20:50
01-05-2021
03:30
20:50
Got a new Versa 3 over Christmas and I'm generally very pleased with it. The only problem so far is that screen wake takes a very long time. Sometimes I have to tap the screen 7 or 8 times for it to wake up and it can take up to 10 seconds. It does eventually come on, and the rest of the touchscreen actions seem fine, but it's annoying that it lacks sensitivity for that first operation.
Is this common, or do I need to re-set it?
Thanks.
Two things,
the back button will wake it,
and try swipe to the right when its on and check all the icons are greyed except the middle bottom one.
Then when you raise your wrist quickly to look at the watch it comes on automatically.
Two things,
Thanks. I use it in Automatic mode (which even then only seems to wake up half the time when I move my wrist rapidly) but I'm just surprised that the screen is so unresponsive to being tapped. Spending up to 10 seconds trying to wake it up seems excessive.
Are you raising your arm and twisting your wrist at the same time?
The motion is as if you are standing with your arms by your side and you want to see the time.
Works perfectly for me, I'm wearing it on the outside of the wrist when standing.
Best AnswerYes, and I seem to be getting better at that specific action. There are just times when I want to tap the screen awake and that seems way harder than it should be, so I wondered if it was a common problem or if I had a faulty screen.
@MishInPDXHave you tried restarting your watch, it may clear the problem.
Best AnswerWhat's the back button? Nothing I press works. I tap all over the screen and try the mystery side button that I still am not sure whether it's the wide indentation or little dot but neither responds very well. It's very annoying,
I've done all the things suggested here and tried both manual and automatic wake settings. Still have to tap it a stupid number of times. But when I'm hiking, it'll jump screens for no reason without touching it. I don't understand it at all. Why don't things come with clear instructions anymore? I can't even figure out the side "button" with no button (and no, I'm not a technophobe). I press it 10 times at different angles and maybe it works.
Best AnswerI am having the same issues with the "haptic button"!
HI @moonbebe11 - it can take a while to get used to the button.
try
Worn on the left arm -
rest your other thumb on the arm to the left of the watch and forefinger on the back of the hand and do a gentle squeeze of the watch. Using a finger nail won't work. |
practice this technique till you are able to turn the face on and off easily.
An even better solution is to swipe the watch face right, when it's on, to get to Quick Settings and ensure the watch/wrist action icon is enabled. Then just raise your wrist to look at the watch and it comes on by itself.
Awesome!! Both techniques worked! Thank you 🙏🙏🙏
I'm new to fitbit. My screen wake is set to auto and my versa 3 is still really slow to wake with a flick of my wrist. Especially in bed at night if I just wanted to check the time.
04-01-2022
23:16
04:21
04-01-2022
23:16
04:21
@SunsetRunner - this is normal at night.
Ideally set a sleep schedule for the night.
When the watch is in sleep mode auto wake is disabled and to see the time you need double tap the watch, without annoying the neighbors, or surreptitiously just push the button to see the time!
