08-08-2022
12:19
17:34
08-08-2022
12:19
17:34
How can I make my Versa 3 show weather in Fahrenheit?
08-08-2022 18:34
08-08-2022 18:34
Hello @ladyivanor
Open your Fitbit App, tap your profile picture then scroll down and tap Versa 3. Now tap Gallery then scroll down and tap weather. Here tap the settings and you can change the weather to show Fahrenheit.
Remember to sync your Versa 3 after you’ve made the changes so that your averse 3 tracker accepted the change.
😃 I hope that provides you with the best answer to your question. Please let me know how it went
08-12-2022 04:23
08-12-2022 04:23
If that had worked, I wouldn't n]have had to post the question.
08-12-2022 08:47
08-12-2022 08:47
Hello again @ladyivanor
I apologize for suggesting how to change the weather unit from Celsius to Fahrenheit in a method you have already tried but in my defense you didn’t mention any steps you had already tried in your original post. This method had worked for many.
I would suggest trying to restart your Versa 3, log out of the Fitbit, restart your phone then log back into the Fitbit App and try again.
Another path you can try is to open the Fitbit App, tap your profile picture then scroll down and tap App settings. Next tap units then scroll down and place a check mark on Fahrenheit. Finally sync your Versa 3 for the changes to be accepted by your tracker.
😉 Hopefully this helps. Let me know how it goes
