06-28-2023
23:45
08:49
06-28-2023
23:45
08:49
Hi all,
anyone else experiencing a quick battery drain on their fitbit all of a sudden?
mine is now only lasting a day when two weeks ago it was still lasting all week! Seems to have inly happened since they have changed the watch faces. Ive noticed the time on mine is always there now instead if a blank screen as it used to be( even though this is switched off in my settings ) have tried a reset but still the same and also have tried charging it over a whole 24 hours too as another thread suggested.
06-29-2023 01:35
06-29-2023 01:35
Hi @Palmerasun - if the time is being displayed constantly it will drain the battery quickly unless it is a recognised Always On clock face, and even then it shortens the life between charges.
There are several options, the watch has an Analog or Digital Always On view and clock faces may have their own. Some options.
In the watch Settings, Display menu you can change the type of Always On view. By changing it it will enable you to determine if the you are using a clock face Always On display or the built-in one. [A clock face cannot detect this change]
Sometimes the problem may come from elsewhere, so try turning off Bluetooth on the phone whenever you are not syncing.
Of course restarting the watch and phone can help sometimes, if the watch doesn't have a fault, such as water getting in.
Best Answer06-29-2023 08:51
06-29-2023 08:51
Hi there, @Palmerasun. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out. @Guy_ Thank you so much for your help!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
