My Versa 3 is 10 days old.
the battery gets drained to 50% in a day.
Hi, @RadhaKrishnaven! That's definitely not typical behavior. I would start with this article, to make sure you're not running anything like always on screen or GPS that might drain the battery quickly. If nothing there looks likely, I would suggest either exchanging the tracker where you purchased it or contacting Fitbit Support directly.
MakMak | Community Council
Best AnswerHi, @RadhaKrishnaven! That's definitely not typical behavior. I would start with this article, to make sure you're not running anything like always on screen or GPS that might drain the battery quickly. If nothing there looks likely, I would suggest either exchanging the tracker where you purchased it or contacting Fitbit Support directly.
