09-01-2023 08:45
09-01-2023 08:45
I had my Versa 3 for 1 year and a half. It failed in the first year of warranty (battery draining too fast) and it was replaced. The replacement unit has the same issue right now, the battery used to last 6 days, not it can't make it through a day. I want to mention that I haven't changed any settings in the watch from when the battery was lasting 6 days to now. The issue seems to be that if you leave your Versa 3 to charge for a longer period of time and don't disconnect it when it got fully charged it seems to damage the battery. Also: the customer team suggested every time to charge it on a laptop USB port. This tells me that they are aware that using a different charger could damage the watch. My watch came with just the cable and no specific charger. This means that you can use any USB charger. Fitbit tried to save money by not including the charger with the Versa 3. To me this is simple: Fitbit didn't design these watches to protect themselves when they are charged for a longer period of time. I love how these posts are closed for replies really quick so people can't express their feelings! If I invest in a smartwatch that only lasts for a year and a half then definitely something is wrong and I feel like Fitbit is trying to make money on my back. Even if I receive a discount for replacement, I can't afford to pay that amount every year or so. I don't like to be a guinea pig and test their products. I am buying a product that should work as advertised! I know for sure that I won't buy another Fitbit product again, regardless of what explanations I would get from the technical support team. Too bad, Fitbit used to be a good brand and I was proud to be a member of it!
09-06-2023 19:27 - edited 09-07-2023 05:04
Sorry, I wasn't aware what the reporting feature does.
Best Answer09-07-2023 04:23
09-07-2023 04:23
Mine was doing this too for the past week. Yesterday, the screen went black and I can't get it back on. It's counting my steps, sleep, etc, and its syncing, but the screen is black now.
Best Answer09-07-2023 05:02
09-07-2023 05:02
Here's an update, I have emailed the Fitbit support the text below and I got an automatic reply that they don't offer email support anymore. Too bad as this now is a safety issue.
"I had to charge the Versa3 watch a couple of days ago and when I picked it up from the charger I found it super hot (around 50 degrees C). This is a safety issue and Fitbit can't hide behind the fact that the warranty is expired. What if I wasn't around to disconnect it, would this watch catch on fire? This also reminded me of the Ionic watch that I had previously and had a similar issue and was recalled by Fitbit in the past. My Versa 3 doesn't turn on at all right now, it is a brick and I can use it as a paper weight!
