08-15-2022
07:50
17:25
08-15-2022
07:50
17:25
I just got mine on Friday and battery is dying every other day or a day and a half. Did you find out how to fix this? I can’t seem to.
08-15-2022 08:58 - edited 07-16-2023 03:42
Hi there, @leshack06. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from.
Are you using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
I've moved your post to the Versa 3 board for organization purposes.
Best Answer08-15-2022 08:58 - edited 07-16-2023 03:42
