03-28-2022
12:09
20:14
03-28-2022
12:09
20:14
Bought the versa 3 in August 2021 the battery is only lasting 3 days instead of 6 days why?
03-29-2022 05:35 - edited 03-05-2024 06:56
Hi there, @CazzyCar. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from.
Are you using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
Hope this helps.
Best Answer03-29-2022 05:35 - edited 03-05-2024 06:56
Hope this helps.
