03-24-2022
11:57
20:17
03-24-2022
11:57
20:17
I recently switched from the Ionic to the Versa 3. This is my 2nd day with it, and the battery is already almost dead. Fitbit advertises 6 days, how can I conserve my battery?
03-25-2022 05:26 - edited 03-05-2024 06:49
Hi there, @CassiePlant. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 3. I understand where your concern is coming from.
Are you using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
Hope this helps.
Hope this helps.
