04-06-2022
20:10
20:14
04-06-2022
20:10
20:14
Hello all,
My Versa 3 battery is draining really fast. Down to 53% from 100% in the last 23 hours.
Since I bought my Versa 3 I've minimized battery use by: turning off GPS, using minimum brightness, turning of automatic wake, never using the music or call functionality, turning off all notifications.
I used to get great battery life until I tried an Sp02 app and that was expected because it's an extra sensor.
I've tried reboots and very recently a factory reset. But the battery life seems to be getting only worse recently.
Is it possible to the Sp02 function to get stuck on?
Are there ways to troubleshoot the hardware?
What are some tricks that worked for your battery life woes?
Hi @MichaelFN have a look at the various options in How to resolve the Major issues causing short battery life
09:02
13:16
04-07-2022
09:02
13:16
Thanks! Fortunately I've minimized all software options. I even did a factory reset and the battery still drains fast.
I am curious about the sync issues possiblity. I'm not getting any error messages about sync issues tho. And I can sync successfully and see updated data in the all. I did disable Bluetooth and reset my phone/watch but the battery still drained.
What do I look for when troubleshooting the Bluetooth sync?
@MichaelFN- leave the phone Bluetooth off and also disable status indicators in the watch settings and restart the watch and control if that improves the battery drain. This is a temporary state and you won't get any notifications or syncing while doing the test.
