08-13-2022
00:16
17:25
08-13-2022
00:16
17:25
Hi I did the versa 3 up update 2 days ago and now my battery only lasts less then a day before this I was getting nearly a week out of it
08-13-2022 04:57
08-13-2022 04:57
Hi there, @Clarebear071981. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 3. I understand where your concern is coming from.
Are you using Snore Detection? If so, please note that the Snore Detection feature does impact your device’s battery, so we recommend charging your device to at least 40% before going to bed. For more information, see How can I use my Fitbit device to detect snoring and noise levels while I sleep?
However, I'd like to share with you that the battery life will depend on how frequent certain features are used in general. Because you're using an Always-On Display clock face, I'd recommend changing the clock face to another one made by Fitbit and monitor your it's behavior in the next day. Additionally, try turning off this setting by opening the Settings app on your watch > Display > Always-on display.
Hope this helps.
08-13-2022 11:58
08-13-2022 11:58
Hi
Thanks for the update put I have none of these on my fitbit it was working perfect until the update and clock face is the same
08-14-2022 16:43
08-14-2022 16:43
Hello. Theres another way it can be draining it.
Go on to your Fitbit watch go to setting then look at your vibration. It may effect your battery life also how old is it if it's old. You may need to get a new one. And also what's your brightness? What's the screen wake time? These all have a big impact on your Fitbit. Hope I help!
