my versa 3 was fine until 4 days ago when charged in the morning, the battery dropped to 23% by 5 pm. This is not normal and usually holds a charge for more than 2 days. Now I’m finding that I need to charge my versa 3 at least 2 times a day. I turned off the spO2 and reduced functions that would drain the battery to no avail.
05-07-2023
11:57
16:55
05-07-2023
11:57
16:55
Hi @Eryn123 - if the watch hasn't got a fault try the following
If the watch gets hot when charging stop immediately, it may have water or other internal damage which can cause sudden short battery life.
If it is under warranty consider getting it replaced.
