05-24-2022 04:03 - last edited on 12-18-2022 19:55 by
My versa 3 screen shows solid coloured lines. I cannot get a clock face or widgets and will not turn off with the buttons.
Does anyone have any ideas I might try to rectify this situation
05-24-2022 11:25 - edited 11-19-2023 02:41
Hi there, @Top13. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
Please restart your Versa 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
Best Answer05-24-2022 20:43
05-24-2022 20:43
Best Answer05-26-2022 07:28 - edited 11-19-2023 02:39
@Top13 If the issue persists even after the recommendations above, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Best Answer05-28-2022 04:57
05-28-2022 04:57
Thank you for your advice, but due to the display itself being corrupted nothing short of a new screen was going to rectify the problem. Thankfully it was still under warranty and was replaced.
regards Top 13
