07-12-2022
07:59
17:47
07-12-2022
07:59
17:47
My fitbit is not calculating my kms correctly. I walked over 15000 steps. Included in this was a 4 km hike. My watch is saying I walked 0.46 km. Not sure how to fix it.
07-12-2022 09:17 - edited 11-19-2023 03:38
Hi there, @Singram. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 3. I understand where your concern is coming from.
Fitbit devices use the formula below to calculate distance. Your stride length is determined by your height and sex. Steps x Stride Length = Distance Traveled
Please note when you track an activity with GPS, your device calculates your distance using GPS data rather than steps. If you begin moving before you get a GPS signal, your device calculates distance using your steps until GPS connects.
To update your stride length, track a run with GPS or measure your stride length manually. For more information, see: Can I change my stride length in my Fitbit account?
For more information about GPS, see: How do I use GPS on my Fitbit device?
Hope this helps.
Best Answer07-12-2022 09:17 - edited 11-19-2023 03:38
Hope this helps.
