07-09-2021
11:09
20:47
07-09-2021
11:09
20:47
I woke up this morning to my watch being dead and I knew it was charged. I put it on the charger and found that it was going through a boot loop over and over again. The logo shows up, the watch vibrates and shuts off and repeats the process.
I took it off the charger and it kept rebooting until the battery died. I try to turn it on now and it shows the logo and then the 0% battery icon.
Anyone know what I can do? I've only had this watch since May...
Hi there, @Kittia. Welcome to the Community Forums. Thanks for the details provided in your post about your Versa 3's behavior. I understand where your concern is coming from.
As a first approach, I'd recommend restarting your Versa 3. For instructions, see How do I restart my Fitbit device?
If the restart doesn't work, I suggest to perform a factory reset by following these steps:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
@Kittia Thanks for trying to follow the steps I provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
Yes, I have the exact same problem. I tried hard reset - no effect. I can't soft reset as the screen isn't displayed. Someone on the online chat suggested I use a small button on the USB end of the charger cable to reset, but there's no button! So I suppose I'll have to progress trying to replace it.
Best AnswerUpdate on boot loop problem. One of the online chat guys told me:
I just had this issue, only had this Versa 3 since beginning of Oct! Online chat person had me go through everything including the 8 seconds yada yada yada....but since the device is unresponsive none of this works. They are replacing mine since it is only 2 months old. This is the 3rd Fitbit I have had over the years and each one has had it's own problems. I will take the replacement but I am switching to a different brand!!!
How long did it take once you sent it in before getting another one?
Best Answerwhen you start ignore the fact that it does not finish to boot. just hold the button until you fell the sort vibration. after a few tries finaly the screen remained on but got the message that the data is not clear with a big red cross and it was stuck there. tried again the above steps with the same result. deleted the watch from fitbit app and it was found as a new watch, accepted, put the code and asked for update. tried to update but after 5% message was that it failed. tried several times with no succes. That happend with a sony phone. tried with a different phone (galaxy s8) and succes. (over the bluetooth) hope this helps someone
