03-28-2023
03:04
06:42
03-28-2023
03:04
06:42
Unresponsive hardly 6 months old yet?!!!
03-28-2023 06:46
03-28-2023 06:46
Hi there, @Pennyplop. Welcome to the Fitbit Community Forums.
Please restart your Versa 3 as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
If the above doesn't work and your Versa 3 doesn't vibrate when performing the restart, I'd suggest trying the following steps:
If the above doesn't work, I recommend performing a factory reset on your Versa 3:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
03-28-2023 06:46
03-28-2023 06:46
03-28-2023 10:03
03-28-2023 10:03
03-28-2023 12:21
03-28-2023 12:21
I've had mine for about a year and it won't let me do anything. I can't even restart it. I saw someone else is having the same issue. Hopefully they get it fixed soon.
