06-02-2022
00:51
17:58
06-02-2022
00:51
17:58
Upgraded to a versa 3 so I could use its new features only to find issues with my note10
i looked here and issues were the same in 2019 and 2020 surly this has been solved
Alexa won’t connect
wallet won’t set up
bitmoji won’t load its clock
calls to the watch are not compatible
among other things
please someone help
or do I have to go back to using my iPhone 8
06-03-2022 05:35 - edited 11-11-2023 09:54
Hi there, @Shaz2022. Welcome to the Community Forums. Thanks for the details provided in your post about the issues with your new Versa 3. We‘re taking your comments and sentiments in regards to our products into consideration.
As a first approach, please make sure that your Note 10 meets the requirements listed here.
Regarding voice assistance, please note Amazon Alexa and Google Assistant are only available in certain languages and countries at this time. For more information, see fitbit.com/voice.
For more general information and troubleshooting steps for voice assistant, see How do I use a voice assistant on my Fitbit smartwatch?
About Fitbit Pay, are you getting any error message? If you’re setting up Fitbit Pay for the first time, you may be prompted to set a 4-digit PIN code for your device. Note that you also need passcode protection enabled for your phone. To make sure you're setting up Fitbit Pay correctly, please visit How do I set up Fitbit Pay?
Regarding Bitmoji, please note our team is aware and they're still working to identify a fix as soon as possible. While I don't have a time frame, make sure to keep the Fitbit app updated.
In regards to the call notifications, are you having issues only with the calls? Do you get any error message? Please make sure to follow Why are notifications delayed or missing?
Hope this helps!
Best Answer06-03-2022 05:35 - edited 11-11-2023 09:54
Hope this helps!
