12-05-2020
		09:30
		20:50
		12-05-2020
		09:30
		20:50
I have successfully paired my new Versa 3 but it won't receive texts. It receives all other notifications from apps. Both Versa 3 and Versa 3 Controls show up in my device settings.
		12-06-2020
		10:13
		03:47
                                          Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
		12-06-2020
		10:13
		03:47
Welcome to the Community, @Fisher4613 and @SunsetRunner, thanks for the input.
If you are having problems with your notifications, I recommend checking the help article: How do I get notifications from my phone on my Fitbit device? and follow the instructions provided there.
Let me know the outcome.
 Best Answer12-05-2020 12:55
12-05-2020 12:55
you need to have your watch very close to your mobile phone, that is the way to get txt message
		10:13
		03:47
		12-06-2020
		10:13
		03:47
 Best Answer12-06-2020 12:11
12-06-2020 12:11
It is the same for me. Messages will not come through at all even when the watch is right next to the phone. My husband bought me this as a birthday present because this is the one I said I wanted and now I'm just extremely disappointed. This is not the only issue I am experiencing.
		12-07-2020
		10:21
		03:46
		12-07-2020
		10:21
		03:46
Hey @SunsetRunner, welcome to the Forums.
I understand how are you feeling and appreciate all the efforts in trying to fix this notifications issue. Have you followed the instructions provided in my previous post? If you haven't, please take a look and follow the recommendations provided.
Keep me posted.
 Best Answer12-07-2020 10:56
12-07-2020 10:56
I am having the same issue, but I am not receiving any notifications from any apps. I have restarted my fitbit, disconnected it from my account and set up a "new" watch again, and I have done everything in the troubleshooting page. Nothing seems to work.
12-07-2020 12:32
12-07-2020 12:32
Thanks for your reply. Yes, I followed the instructions on the help article prior to posting to this forum, but it didn't help. Could I speak to someone?
12-08-2020 19:37
12-08-2020 19:37
Go to actual messenger setting on iPhone and make sure notifications are set to always
 Best Answer12-09-2020 00:47 - edited 12-09-2020 00:48
Thank you! I ended up having to reach out to support and I finally figured it out. You have to have preview set to always or when opened. They must have changed their settings because it used to be ok to have preview off (I’ve had my preview off for 6 years and Fitbit for only 5 and has only recently - maybe 1 year - has my notifications not worked).
12-09-2020 06:35
12-09-2020 06:35
UPDATE: I spoke to Fitbit tech support and they stated that this is a known issue and they are working on a resolution.
12-09-2020 13:58
12-09-2020 13:58
Had the same problem yesterday. Made this change to my iPhone notifications setting and it works! Thank you!
12-09-2020 19:02
12-09-2020 19:02
Same issue for me despite following all your instructions on your post
		09:55
		03:48
		12-10-2020
		09:55
		03:48
Hey guys, thanks for your participation in the Forums.
As our friend @Fisher4613 mentioned, we are aware of the problem and are working to resolve it as quickly as possible, sorry for any inconvenience it's caused and appreciate your patience and look forward to getting you back on track.
Please let me know if there's anything I may do to assist you in the meantime.
12-12-2020 15:49
12-12-2020 15:49
I do. It shows paired but does connect
		17:21
		09:33
			AlejandraFitbit
		12-12-2020
		17:21
		09:33
			AlejandraFitbit
I just bought a brand new versa 3 and it syncs but will not receive any notifications on my fitbit. Im about to take it back! Same. Im about to return my versa 3 that I just bought. Me either.
Moderator Edit: Formatting
		12-13-2020
		09:37
		03:48
		12-13-2020
		09:37
		03:48
Hey @ABCHAMP2 and @Razzle3710, thanks for your participation in the Forums.
As mentioned, we are aware of the problem and are working to resolve it as quickly as possible, sorry for any inconvenience it's caused and appreciate your patience and look forward to getting you back on track.
 Best Answer01-04-2021 22:56
01-04-2021 22:56
Hey, have you guys been able to fix this in the meantime? I have the same problem and kept restarting my smartphone, the app and the Versa 3. Every now and then it worked for 30 minutes and then suddenly it stopped working.
 Best Answer01-06-2021 01:02
01-06-2021 01:02
Hi, Are you able to resolve the issue ? My Versa controls keep getting disconnected and I do not receive any notifications.
 Best Answer01-08-2021 13:54
01-08-2021 13:54
Hi Alejandra, it is the problem solve? Because, when my mobile conects to the versa 3 controls, fails de connection to the calls.
How can I do, to solve this??
Thanks.
 Best Answer01-08-2021 14:13
01-08-2021 14:13
2nd UPDATE: Unfortunately, I haven't heard back from tech support and the problem still isn't resolved.
