03-30-2024
18:38
05:46
03-30-2024
18:38
05:46
I noticed I can see 2 different watch face numbers burned into screen in background after changing to a new face. The worst is the always on clock. When turning on a white flashlight app I can see the green numbers really bad. I have tried restarting watch, and different faces. Looks like oled burn on a TV screen.
Hi @ryadre - this screen burn can happen if the clock stays on a particular display for long periods and can be more noticeable on certain views with non black backgrounds so try and choose a clock face with a black background and avoid Always On mode.
Of course if you are under warranty (unlikely for it to happen in such a short time) it can be replaced but if the watch is working fine otherwise it may not be worth it in case the refurbished replacement isn't as good in some other area.
Best AnswerYes the always on mode with black background and white time is on during the day, then I set to sleep at night. Pretty poor really that it does this. No it won't be under warranty anymore,probably 2 or 3 years old now.
