01-11-2022
00:19
20:37
01-11-2022
00:19
20:37
I've had my Versa 3 just over a year now and up until 4 days ago it was counting flights of stairs just fine (20+ a day) now it doesn't record them at all. My phone and Fitbit on the most recent updates. I've also factory reset my Versa 3 but it has made no difference. What else can I try?
01-11-2022
04:40
10:33
01-11-2022
04:40
10:33
Hi @MickyCo - To be really certain it is not a problem with the Fitbit App or the current clock face, on the watch click on the Today app icon and see what floors say, if they are not shown, click EDIT and add the information to show.
There is a tiny hole on the side which may have got blocked. Do not stick anything in it as it will destroy the sensor, but try cleaning it very carefully. It may be necessary to restart it after the clean. See How do I clean my Fitbit device?
01-11-2022 05:42 - edited 03-30-2024 16:14
Hi there, @MickyCo. Welcome to the Community Forums. Thanks for the details provided in your post.
Please keep in mind that your watch tracks floors by measuring changes in air pressure through a small hole in the back of the Versa 3. If this hole becomes blocked then it can cause this problem. With that being said, please (as @Guy_ mentioned) try cleaning it with by following these steps: How do I clean my Fitbit device?
Nevertheless, please don't forget that Fitbit devices that count floors have a small hole (altimeter sensor) on the back of the device so please don’t insert any items, such as paper clips, into this hole as you can damage your device.
01-12-2022 08:13
01-12-2022 08:13
Hi @Guy_ and @MarreFitbit thank you for your advice. Yes it does show the floors on the today app (as 0). I gave it a gentle clean yesterday evening and restarted my watch but still no luck unfortunately. 0 flights recorded today. Anything else I can do please?
01-12-2022 20:49
01-13-2022 04:24 - edited 03-30-2024 16:14
@MickyCo I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Best Answer01-19-2022 12:51
01-19-2022 12:51
I'm having the same problem. Was working fine one day but the next nothing. It's been a week or more now. Getting so pissed.
01-20-2022 05:38 - edited 03-30-2024 16:13
Hi there, @linlit. Welcome on board. I'm sorry to hear about this issue with your Versa 3, I understand how you must be feeling.
To better assist you, please make sure to follow the tips and recommendations provided in this post.
Hope that does the trick for you.
Best Answer01-28-2022 12:26
01-28-2022 12:26
I followed all your tips and today did a factory reset. Still not registering floors.
01-28-2022 22:19 - edited 01-28-2022 22:26
Hi @linlit - you can try the SimpleFloors app.
It shows how your watch is affected by environmental issues such as, going room to room, upstairs/downstairs, inside to outside, changes in temperature, etc.
If it is not registering pressure changes the sensor hole could be blocked or there is a watch fault or a fault in the firmware or it is simply necessary to restart the watch..
This app is meant for checking purposes as it uses the battery a lot, but at least it will give you an idea if your watch is fine or if it is some other issue.
