05-02-2022
16:00
20:02
05-02-2022
16:00
20:02
Versa 3 not charging, stuck on 17%. Watch face only showing Fitbit icon. I’ve logged out & logged back in with no result.
pleas send heeeelp!
05-02-2022 16:20
05-02-2022 16:20
Hello @dharps18
I would try restarting your Fitbit Versa 3. You won’t lose any data doing so. Just press and hold down the button on the side of your tracker until the Fitbit Logo appears. When the logo appears release the button. You will feel the tracker vibrate indicating the Fitbit has finished restarting.
I hope this provides you with the answer your seeking. Please let me know.
😃 Happy Stepping!
Best Answer05-03-2022 09:24
05-03-2022 09:24
Hi there, @dharps18. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 3. I understand where your concern is coming from.
Since your Versa 3 is stuck on the Fitbit logo, please try the following steps:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
05-03-2022 15:09
05-03-2022 15:09
