11-28-2022
06:32
16:58
11-28-2022
06:32
16:58
My Versa3 is only 7 months old but it is stuck on the fitbit logo, I have tried rebooting and disconnecting but now I only have the fitbit sign, nothing happens, how do I get this fixed or replace or a refund - the last is my preference as this is my second Fitbit not working.
I have the receipt and paid by credit card, please can anyone advise? Thanks
11-28-2022 12:45 - edited 07-24-2023 08:11
Hi there, @nagromanit. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Please note the issue you're having comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings.
Before considering other options, please make sure you've followed all steps listed below:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If none of the above works, please follow @Guy_'s advice.
07:05
07:37
11-28-2022
07:05
07:37
Hi @nagromanit - it is covered by warranty from where you bought it.
If you take it back to the shop they may replace it over the counter with a new one, or if you bought direct from Fitbit they will send you a refurbished one without any of the accessories.
But first perhaps try chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support in case they can get the factory reset to work.
