12-20-2022
		18:39
		09:18
		12-20-2022
		18:39
		09:18
After the last update 3 days ago my exercise tracking function would not work. I unpaired my device and attempted to re-pair. Disaster! Not only will the device not re-sync the Fitbit logo just keeps flashing on the screen. I can’t turn the device off (unless I let it run of battery life). Is there any suggestions on how to solve this problem?
12-21-2022 09:19
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              12-21-2022 09:19
Hi there, @Mflinn. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Please note this issue comes from performing a factory reset without first unpairing your Fitbit device from your Fitbit account and phone's Bluetooth settings. With that being said, I suggest following the steps below in the order listed (or making sure you've done them as instructed):
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
12-21-2022 09:19
                              12-21-2022 09:19
Hope this helps.
12-29-2022 01:29
12-29-2022 01:29
Shut off your phone and turn it on after 1-2 minutes. Turn on the Bluetooth. Set up your Versa 3 again. If there is no connection, restart your Versa 3.
Regards,
Will
