03-01-2023
19:04
05:16
03-01-2023
19:04
05:16
My versa 3 has been looping the main Fitbit logo and vibrating every 8-9 seconds. I tried all troubleshooting methods I could find and none have worked. Disconnecting Bluetooth, turning off my phone, disconnecting the Versa from my phone, etc. This has been happening for 12 hours. It will simply not reset manually or be detected via Bluetooth on my phone. Has anyone experienced this and have a solution?
03-02-2023 05:18 - edited 06-08-2023 04:09
Hi there, @CaitG_1991. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
If the steps recommended by @Guy_ don't work, as our last resort, I suggest to perform a factory reset by following these steps:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Best Answer03-02-2023 02:07
03-02-2023 02:07
Hi @CaitG_1991 - a reboot loop means something went wrong - see this post Sense stuck on a reboot loop
Best Answer03-02-2023 05:18 - edited 06-08-2023 04:09
Best Answer03-02-2023 07:58
03-02-2023 07:58
Mine has been doing this all morning as well. Called support and they are NO help! Told me to troubleshoot all the same things already done here. I see above that there is a widespread issue, so maybe that is the problem, but the guy on the phone would not admit the ongoing issue. Figures!! Hope it is resolved soon. I have owned a Fitbit for the past 10 years and will not be buying any more if this is not resolves. They will lose a loyal customer!!!
03-02-2023 08:21
03-02-2023 08:21
I normally don’t have any issues that won’t be resolved in a few hours, or with a device reboot. I hope they fix it up for us! I’ve been a customer for about the same amount of time! This has been going on for me for about 24 hours now. It’s just frustrating, I thought it was just happening to me until this morning!
