11-28-2023
18:18
03:45
11-28-2023
18:18
03:45
I have tried restarting by holding down button for five seconds, ten seconds, fifteen seconds and the 60 second restart option all advised on Google.
I am still stuck on Fitbit screen
I have also tried discharging the battery and it is still on fitbit screen.
Is there a pinhole reset battery option?
11-29-2023 03:51
11-29-2023 03:51
Hi there, @Susan_Maree. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Versa 3 is still stuck on the Fitbit logo despite all the steps you've tried so far. I understand where your concern is coming from, I'll be glad to continue assisting you.
In addition to the steps you've done so far, please confirm whether you've tried the steps below in the order listed:
If you can't get started with your Versa 3, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If the above doesn't work, as our last resort, I recommend performing a factory reset as follows:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Hope that helps.
11-29-2023 11:33
11-29-2023 11:33
11-29-2023 12:20
11-29-2023 12:20
I had the same problem, and I was ready to throw away my Versa 3, but I called the Fitbit help and the lady on the phone guided me through a similar process that solved the problem. Unfortunately, I did not record the steps I went through.
From what I recall, you have to re-do the watch setup from you phone app, first removing the current Versa 3. Then my app discovered the "stuck"Versa 3 started the set-up and at the end it was functioning well again.
Hope this helps... or call the help desk!!! Best luck to all of you stuck like I was 🙂
11-30-2023 21:18
11-30-2023 21:18
Many thanks for your advice to keep persevering. I was ready to throw it away also. I disconnected the device from the Fitbit App, deleted the fitbit app. I also deleted the connection to Bluetooth and forgot the device. Turned off the phone and walked away from the problem for a while. Started trying the factory reset again and on about the fifth try it worked. I reinstalled the app and reset up most of the device how I had it. I also got very good detailed advice on this forum from Marrefitbit. Thank you for for replying to my problem. Much appreciated.
11-30-2023 21:20
11-30-2023 21:20
Thank you very much for your detailed instructions. It took a long time and a lot of fiddling around but everything is working again.
