08-15-2022
11:48
17:25
08-15-2022
11:48
17:25
Change time from central time to daylight savings
Hi there, @seawolfmartin. Welcome to the Community Forums.
To better assist you, would you mind providing more details about the issue with your Versa 3? Is the time not changing? Is your Versa 3 not syncing?
Note that the time on your Fitbit device may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Inspire is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I change the time on my Fitbit device?
Hope that helps.
Best AnswerI have had a lot of difficulty getting the versa 3 to change time zones. Sync alone didn't work. I had to shut down Versa 3 and restart, then it usually synced time zone, although sometimes still a bit of delay.
I think it's part of the general sync problems.
