Versa 3 weather display
ANSWERED
My versa 3 weather was working great in my setting of Fahrenheit until I got a new android phone and now it is stuck on Celsius. I have uninstalled app,reinstalled , cleared cache and all with no luck! It is so frustrating.
1 BEST ANSWER
Accepted Solutions
Hi @CD82 - just in case, make sure to turn off your old phone to ensure proper syncing on the new phone.
Change the weather temp as instructed and restart the watch and sync.
If this stil doesn't work, restart the watch and immediately change the weather settings before the watch has fully restarted.
If it is still not working, more drastic measure is needed, logout of the Fitbit App, swipe it off, and in the phone settings for it, force stop it and clear the cache.
Then login and try again.
4 REPLIES 4
Hi @CD82   If you are trying to change the unit isn the 'normal' app settings (profile picture > Fitbit settings > Date, time & units), that sets the units for skin temperature variation or if you log your temperature.  The temperature units for Weather are in that app setting.  Tap on your device/battery icon, then your Versa 3 tile.  Tap on Apps (center, below your Versa 3 image).  Locate your Weather app.  Tap on Settings and change it there.
The Weather app had a weird way of resetting itself on my Versa 3.  I often had to restart it to make a time zone change.  Every time I restarted it, the setting went back to Celsius.
Laurie | Maryland
I have set it there but it makes no difference even with restarting Versa.
I posted because I felt like I tried everything that I learned in fitbit
help. It all started when I upgraded my Samsung Galaxy smartphone and
fitbit app is different.
@CD82   I’m sorry, but I don’t have any other suggestions.  That is the only path I know and used.
Laurie | Maryland
