Versa 3 weather units
My versa 3 won't change from Celsius to Fahrenheit
Moderator Edit: Clarified subject.
1 REPLY 1
Hi @Musicman1535Welcome to  the Fitbit Community! It's great to have you here!
I'm glad to help you set the correct temperature units on your Versa 3.
There's a section in the settings on the Fitbit app to change temperature units. However, to change the units used for the temperature in the Weather app of your Versa 3 you need to do as follows:
  • From the Today tab in the Fitbit app, tap the devices icon your device Gallery Weather.
  • Tap Settings.
  • In the Temperature Unit section, tap Units and choose the unit you want to use.
