12-28-2020
12:42
20:50
12-28-2020
12:42
20:50
I really need help. I cannot switch my Fitbit Versa 3 on. I've done what people have suggested and held all the buttons to reset it and I've charged it for hours. Nothing is working. Please help me, I've only had this watch for two weeks 😞
10-04-2022
10:36
02:21
10-04-2022
10:36
02:21
Hi everyone, and welcome to our new members.
Thank you for sharing your experience and troubleshooting. If your Versa 3 display is unresponsive, try restarting it by doing the following:
If the issue persists, please get in touch with our Support team. Hope this helps!
12-29-2020 05:11
12-29-2020 05:11
Hello Sophs26,
Sounds faulty to me if the screen is blank are you pressing the button in the correct position?
Mitch.
12-29-2020 06:18
12-29-2020 06:18
Hello there @Sophs26, welcome to the Community Forums. Thanks for trying to troubleshoot your Versa 3 before reaching out. I totally understand how you must be feeling. Thanks for your input @MItchfit66!
Did you feel any sort of vibration on your watch during the restart process? If you didn't, please try the steps below:
Let me know how it goes.
03-22-2021 13:01
03-22-2021 13:01
Did you get your versa 3 sorted, mine has done the same
03-22-2021 13:33
03-22-2021 13:33
Hi there, @Leanmil. Welcome to the Community Forums.
If you're going through the same issue with your Versa 3, please restart your watch as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
03-22-2021 15:16
03-22-2021 15:16
Nothing is working, it won't even charge, no vibration nothing, it was on with 89% and I noticed it wasn't ringing or receiving text messages so I turned it off hoping to restart but I'm getting nothing from it at all, just dead
03-23-2021 04:30
03-23-2021 04:30
Still nothing. Apparently this has been happening to a few people and I'm not the only one. I wish there was a simple way to resolve the issue. I can't even restart it, it just sticks on the fitbit logo
03-23-2021 04:39
03-23-2021 04:39
@Leanmil @Sophs26 Thanks for following the suggestions I've provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
03-23-2021 23:18
03-23-2021 23:18
I managed to get it on by connecting charger and disconnecting a few times quite quickly, but can't connect to calls and doesn't vibrate with texts regardless or the settings being correct, so disappointed 😑
Best Answer03-25-2021 03:46 - edited 03-25-2021 03:47
@Leanmil I understand how disappointing this can be. Please be sure to follow my last recommendation from this post.
We look forward to getting you back on track.
04-27-2021 08:05
04-27-2021 08:05
Same issue - fully charged, brand new, won’t turn on - what an entire was if $ a should’ve just stuck with my reliable charge
04-27-2021 08:11
04-27-2021 08:11
Hi there, @Giteacher2. Welcome on board. We‘re taking into consideration your comments and sentiments with regards to our products and services.
In order to move forward, please confirm that you've followed the steps I recommended here.
Hope that does the trick for you.
05-21-2021 09:06
05-21-2021 09:06
Mine just did the same thing. I turned it off to change the band, and it wouldn't turn back on.I've had nothing but bad times with this thing. I won't get into it, other than to say, this much money for a cheap wish.com knock off quality of an item is insane!
05-21-2021 11:17
05-21-2021 11:17
Hi, my Fitbit 3 has just died too. No matter what I do, including everything you have suggested to do, it will not turn on. Does this mean the device, which I've had since April 2021, is faulty?
Best Answer05-21-2021 11:27
05-21-2021 11:27
I have spent the past few hours looking into this issue. By the end of next week all of the Versa 3s will be stuck in this non bootable state. Very poor quality. I knew I should have sent it back the millisecond I saw that $0.03 watch band. Wal-Mart's throw away kids watches have better bands, and they are only $5. Then waiting on an after market one, my wrist broke out in blisters from the horrible quality band, never got more that 2.5 days before it had to be recharged, and now this non boot issue. SMH.
05-21-2021 11:37
05-21-2021 11:37
I have been trying to turn my back on for some time now too. I couldn't get it to sync in the app, had to shut down and it won't turn on at all. I've had other issues with it too as someone else pointed out. I truly hate this watch.
05-21-2021 12:02
05-21-2021 12:02
This worked for me. Hold the button down for 8 seconds, let off for 1 second and hold it down again until it vibrates,. Let it boot. it's slow.
05-21-2021 12:14
05-21-2021 12:14
Mine never vibrates no matter how many times or how long I press the button. It's like my sensor is gone after less than 3 months. Seems like a flaw in the haptic button and there should be a hard reset option, secondary button etc. I wish I had never purchased this watch.
05-21-2021 12:26
05-21-2021 12:26
I still wish I hadn't of bought mine, too. I hate this over priced junk. I found by connecting the charger, hold firmly on the screen and charger, tapping the side button with three slow taps, it will vibrate once. then I left it on charge for a while, and the 8 second on, 1 second off, and hold until vibrates and a slow boot, worked. Give that a try. If that doesn't work, see if they will replace it or refund it. Mine is just under two months old, I wanted my money back, but it started working again.
05-22-2021 00:30
05-22-2021 00:30
I finally got it sorted and made sure my battery never got flat until yesterday, I got caught out, now my watch has gone onto some kind of lock which I can't get off, the watch is in darkness, tried the settings but not working, I can really say this is the worst purchase I have made, wish I had bought the galaxy watch now😔
