05-01-2022
21:06
20:02
Hi there, @Mark1669. Welcome to the Community Forums. @Fleming478 Thanks for helping out! 🙂
Is your Versa 3 not vibrating at all? I was wondering if your Versa 3 does vibrate with your silent alarms? Your watch vibrates to alert you at various times, including if you set an alarm, when you hit your step goal, or if you haven’t met your hourly activity goal. Have you see if the vibration is also missing for these features?
If your Versa 3 didn't alert you, make sure you successfully set an alarm. For more information, see How do I manage alarms on my Fitbit device?
If you correctly set the alarm or aren’t receiving other alerts, test your device’s vibration motor. Connect the device to the charging cable. For more information, see How do I charge my Fitbit device?
Also, note that when you turn on the Do Not Disturb, Quiet hours, or Driving mode setting on your phone your watch receives notifications, but it won’t alert you. For more information, see How do I navigate my Fitbit device?
Hope that helps.
Hope that helps.
