08-29-2025 07:45
08-29-2025 07:45
A few days ago I found the fit bit, now out of battery and decided to give it another try. After resetting and reinstalling the app I wore it for all of 48 hours before it froze again!
Is there any to remedy this or is my Versa 4 a useless ornament?
08-29-2025 09:51
08-29-2025 09:51
Hi there, @SaraJane01. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 4 keeps freezing. We‘re taking your comments and sentiments in regards to our products and services into consideration. I will do my best to help you with this!
Is your Fitbit device still not charging? Please note that there are some issues that affect this, being which power source is used and how clean the contacts are and how well the charger is seated. If you are charging your Versa 4 on the wall socket, try using another CE certified USB adapter for low energy devices.
If you haven't done so yet, I'd recommend following the tips and recommendations provided here Why isn't my Fitbit device's battery charging?
Once you make sure that your Versa 4 is fully charged, I'd like to recommend the following steps to fix the issue with the screen:
If the above doesn't work, please restart your Fitbit device once again as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer08-30-2025 08:59
08-30-2025 08:59
Thanks Marre, I managed to do a soft reset without losing anything. However it's the fact that this keeps happening with no common factor like clock faces. This means that as a watch it is unreliable, yesterday I was late meeting a friend as I thought it was 2.20, it was only when I checked the time again that I realised it had happened! I guess my main query is how to stop this happening so frequently, or do I put it back in the drawer?
Best Answer08-30-2025 13:49
08-30-2025 13:49
@SaraJane01 Thanks for getting back and for following the troubleshooting steps I recommended. I'm sorry to hear that you were late with the meeting with your friend due to this issue with your Versa 4.
To better assist you, I suggest reaching out to our Support Team who will be able to take a closer look into this issue and provide further help. This form is only meant for you to use. Click here to get access to it.
