05-14-2019 07:45
05-14-2019 07:45
My Versa BPM was working but after running out of battery and recharging the BPM is not working properly. I have tried all of the fixes mentioned i.e. restart Versa by holding the back button and the two front buttons and resetting; tried restart; tried turning on and off the BPM setting. The only thing I haven't done is reset to Factory settings. Not sure I want to do that before checking with the community.
05-14-2019 09:27
05-14-2019 09:27
It might help if you could give more detail about how BPM "not working properly": symptoms, specifics.
Best Answer05-14-2019 14:42
05-14-2019 14:42
When it is reset it appears to be working fine. Then after a few minutes, it will start recording high BPM like 135, then jump to 160, then back to 113 BPM.
Best Answer05-22-2019 02:49
05-22-2019 02:49
No fixes worked. My Fitbit was under warranty, should receive a new one in the mail today.
