The little square thing that holds the strap in place has broken, the band itself is in perfect condition. Is there a way to buy just the little square piece that broke?
Hi @Pholt08 you can't buy just that little piece. If you're still under warranty, you could see if the band is covered. If not, you could always use a small pony tail rubber band to hold the flap of the strap down. Let us know.
Stepping in the U.S.A. since September 2013. Android 14
