Versa Black Screen Issue.
Versa working fine two days ago. Now has black screen issue. Tried restart and factory reset. Can feel vibration & green lights on back flashing. Device was synching but removed pairing with phone to factory reset. Stuck.
1 REPLY 1
@Dave160 If you have just removed Versa from paired devices list on your phone, you should still be able to re-pair it as this is facilitated by fitbit app itself. If you have removed Versa from Fitbit mobile app, I am afraid, you will not be able to do that as your screen is blank. You can attempt another factory reset using buttons:
  1. Press and hold all 3 buttons until Fitbit logo appears (this may take up to 3 minutes)
  2. Release the bottom right button
  3. Wait until you feel strong vibration and release the other buttons.
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
But, at this point I am afraid you may need to reach out to Customer Support to guide you through the next steps. Here's the link to Customer Support page.
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
