09-27-2019 09:36
09-27-2019 09:36
Has anyone else had or got this problem the time on my versa has started to go slow when this happens it won’t sync on my phone it won’t connect via Bluetooth I have to go through switching Bluetooth off forgetting device removing it from my account reinstalling app etc etc and when I do get it to connect it only lasts for a short while
09-29-2019 01:47
09-29-2019 01:47
after many attempts to connect my versa to my phone 5 emails later with the same info from support that makes the versa connect for a couple of hours then starts to loose time and won't connect or sync
i have to constantly set my versa up as a new device now its taking about an hour to find the device and when it dose it generates a number to put into the app software then it fails
has anyone else had these issues
iPhone 8 plus
iso13 with the latest update
09-29-2019 12:26
09-29-2019 12:26
@andy_glass It's the latest iOS update. There were changes in Bluetooth settings introduced by Apple. Those will have to be addressed by Fitbit mobile app update. For now, please try this:
Best Answer09-29-2019 12:49
09-29-2019 12:49
Best Answer09-29-2019 12:50
09-29-2019 12:50
I have tried your instructions twice and both times the versa never appears in the Bluetooth so I can’t continue any further ?
Best Answer09-29-2019 13:00
09-29-2019 13:00
@andy_glass are you trying to pair it manually from your phone's bluetooth settings? This should be done from within fitbit app. Reboot your phone, reboot Versa, open fitbit and this should prompt Versa to sync. If it's no go, I would try to pair and sync with other device - tablet or other phone, and then trying to sync again with your iphone. I remember that trick used to work for me when I was an iphone user. 🙂
Best Answer09-30-2019 05:14
09-30-2019 05:14
@andy_glass it's great to see you in our Fitbit Community! By the way, I'm sorry for the late response. However, I would like to follow up on the Bluetooth connection issues that your Versa is experiencing.
I appreciate the time spent trying the workaround you mentioned above.
I'd like you to try the troubleshooting steps that are listed in this help article. This article may contain steps that you already tried but you can skip them and proceed with the rest. Finally, monitor your watch and see if the issue gets fixed.
Keep me posted on the outcome! 😀
Best Answer09-30-2019 13:52
09-30-2019 13:52
I am trying to connect the versa through the app it took 7 hours at on point to find the versa connected for a couple of hours the the app came up can’t find device I have to constantly set it up as a new device today when I did this it flashed the pairing numbers on the screen for a very time then disappeared and if you manage to read the number it fails and generates another number this continues till the number stays on the screen when you put this number it sets up but after an hour or so it drops the connection again and the setup as a new device has to be run again
Best Answer09-30-2019 14:23
09-30-2019 14:23
@andy_glass this is a nightmare. ugh. My best gut feeling tells me it's due to iOS13 as there seem to be a lot of bluetooth issues related to this update. Good thing is it will get corrected. Nevertheless, if it was me I would still try pairing/setting up my watch using non-iOS device. Just to make sure there's no issue with the watch itself.
Best Answer10-05-2019 13:30
10-05-2019 13:30
email I got today from Fitbit
after 14 emails trying to fix my versa
We appreciate you getting back to us and for providing us with additional information that will help us to better assist you.
We'd like to let you know that we’re aware of it, but may not be able to provide a fix in the immediate future. We'll continue to monitor the situation, and keep our team informed of the impact to you and other customers. We understand that this isn't the resolution you're hoping for, but rest assured we're always working to improve our products.
We hope for your understanding regarding this matter.
We apologize for any inconvenience this has caused. If you have questions, don’t hesitate to contact us back.
Sincerely,
Christine Z and the Fitbit Team
Best Answer10-05-2019 13:47
10-05-2019 13:47
email from Fitbit today after14 emails and loads of instructions that didn't work
Sincerely,
Best Answer10-05-2019 13:49
10-05-2019 13:49
Sincerely,
Best Answer10-08-2019 09:08
10-08-2019 09:08
@andy_glass At this point, I would pair/sync using other device. Also make sure you update Fitbit app as soon as the new version is available in the App Store. There was one for Android so perhaps one for iOS is coming soon too. Support won't know the dates for fixes and new releases.
Best Answer10-08-2019 09:33
10-08-2019 09:33
Best Answer10-08-2019 09:44
10-08-2019 09:44
@andy_glass hmmm not syncing for several hours should not "slow down" the time much, so this is weird. Also, does your daughter uses iPhone? I guess what I am trying to figure out if there is another issue here - i.e. if there's a problem with the tracker itself that would warranty a replacement. It would be good if you could test the sync with the device other than iPhone. I know you have no easy access to such a device, but that's all that comes to my mind beside waiting.
Best Answer10-08-2019 09:58
10-08-2019 09:58
Best Answer10-08-2019 10:23
10-08-2019 10:23
Never works. I have been dealing with this for 9 days now. After day 5 I stopped contacting customer service when they explained that I had tried everything and would just have to wait for it to be fixed. I have managed to get my versa to sync once every 2 days but it doesn't last.
Best Answer10-08-2019 12:41
10-08-2019 12:41
