Has anyone else's versa battery died and then after charging to 100% the display will NOT show even after resetting the device? It's fully charged, the green light on the back works, but the display is a white bar on the top of the screen...and if I reset it, the screen turns different colors and is all full of lines...I did NOT drop it and I havent even showered with it--much less swim 50meters...
Best AnswerSimilar issue: battery died and then when I finally got it back on the display was negative. It flickered badly and it was white where it should have been black and vice versa. Nothing happened except the battery died.
Did a factory reset and that did not work.
I am planning to returning it to Target tomorrow for a replacement m
Best AnswerGoing through this now. Did you order directly from FitBit? If so, how long did the entire process take for you to get back a new one?
Best AnswerThe tread "Blank Versa Screen" has the same complains.
Trying to consulate all the dead and died complains to get an action plan.
C
