03-20-2020 12:15
03-20-2020 12:15
On my Fitbit phone app the firmware version listed for my Versa is VERSION 32.33.1.30
How do I update to version VERSION 32.70.7.14 - which appears to be the latest version?
03-20-2020 17:25
03-20-2020 17:25
@Skier7667 You can attempt performing a factory reset (restoring versa to factory defaults) which should enable you to download the most recent version of the firmware available. Before factory reset, make sure you have deleted versa your phone's Bluetooth settings (not Fitbit app). To perform factory reset, open settings app on you Versa and scroll down to About. Tap it and choose factory reset. This will wipe all data from your tracker so it would be good if you could sync it first. After factory reset you will need to set up your versa again by adding a replacement device in your Fitbit mobile app. You can set up the watch back to the Fitbit account by following the instructions on this link: How do I set up my Fitbit device?
03-20-2020 17:25
03-20-2020 17:25
06-18-2020 09:57
06-18-2020 09:57
So after the latest update, versa settings Brightness, Do Not Disturb and Screen Wake are grayed our and don’t work. How to fix this?
