Best AnswerWell it shouldnt be that difficult and your phone is on the the Supported list so should work well with it. Id try restarting the Versa several times. If it is not functioning any better do a factory reset (settings app on the Versa and scroll down to About). If it is still not working correctly either return it to where you bought it for an exchange or contact Support (link in my signature)
Helen | Western Australia
Thanks NellyG. I will give it a go.
