10-25-2018 07:17
10-25-2018 07:17
I've had my Versa about 6 months and about 2 weeks ago the HR sensor stopped working. I've tried turning it off and on repeatedly. I've made sure that the app was up to date; I even uninstalled and reinstalled the app. I've unpaired my Versa and re-paired. I've checked the forums and tried troubleshooting. I've seen plenty of posts saying to go to the settings and check to see that HR is turned on or auto.... I can not find that in the app or the website! The band is fitting properly, not too loose or too tight. The green light is still flashing and the area is clean but it is not sensing a HR. I've even tried wearing it on my other wrist. What other options do I have? I really like the Versa otherwise but part of the reason I bought it was for the HR monitor.
Best Answer10-25-2018 08:19
10-25-2018 08:19
Because the Versa is a Smart Watch rather than a tracker HR is turned on on the watch itself (settings app) rather than the phone app as with other trackers.
Have you tried restarting your Versa several times? Give that a go if you havent. Ifbthat dpesnt fix it try a Factory Reset (settings app and scroll down to About). Let us know how you go
Helen | Western Australia
10-25-2018 08:19
10-25-2018 08:19
10-25-2018 09:03
10-25-2018 09:03
Thank you. I looked literally everywhere else other than on the watch for the settings. I feel a little silly now but thank you!
