My Versa heart rate reader suddenly stopped working. I have use every troubleshooting tip I could find. I have done everything from restarting it to a complete factory reset. The heart rate tracking is on, the green lights are not flashing on the bottom. Does Fitbit offer any kind of repair options?
Hi again! I found this:
Are the LED lights on the back of your tracker ON? If not, please open Settings app on your Versa, scroll down to Heart Rate and toggle OFF an ON several times, then reboot the tracker by holding the left button until the screen turns off and the fitbit logo appears. Other things to remember - make sure that the battery is not critically low as this may turn off HR sensor. Make also sure you wear the band tight enough and you do not have any tattoos on the arm. And it worked for me!
