02-11-2021 16:15
02-11-2021 16:15
I have a Versa Lite that I love. However, recently I have found that the watch is not staying connected to the app.
If it does completely die, I have to delete my fitbit app and log back in. Then I have to sync it all over again, which it doesn't always want to do. Sometimes it will pop up and say "error can't find fitbit."
It is extremely inconvenient to have to delete the app over and over again in order tk be able to get my notifications on my fitbit. That's why I upgraded to this watch in the first place.
Does anyone have solutions? I have tried shutting my fitbit down while also logging out of the app and then logging back in with it on. I also checked to make sure I have the most up to date software on it. Nothing seems to solve the issue and it is completely random when it does decide to stop syncing.
Best Answer02-11-2021 22:01
02-11-2021 22:01
Seems like this is a common issue. Possibly due to a recent update for iPhones, if it was working before.
In which case its probably best to inform Fitbit Support directly. They may be able to help you.
Best Answer02-11-2021 22:16
02-11-2021 22:16
I have an android device so the iPhone update wouldn't be the issue.
Best Answer02-11-2021 22:59 - edited 02-11-2021 23:00
Thats good, it may be resolvable.
First thing to try, which avoids deleting the app
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
Best Answer02-11-2021 23:06
02-11-2021 23:06
if your watch loses sync then it could be an optimisation issue, try
On the phone check battery optimizations [the options may be different in your version]
Also do the previous clear cache operation after the change. |
Best Answer02-12-2021 09:05
02-12-2021 09:05
Nothing you say works, Fitbit Versa Lite is just junk along with All Fitbits, waste of money only worked for a year now its just junk
