10-24-2020 17:56
10-24-2020 17:56
My versa lite recently stopped syncing to my phone. I have taken several steps to trouble shoot the issue. Here's what I have ALREADY done:
1. Turned the bluetooth on/off on phone
2. Restarted my phone
3. Updated my fitbit app
4. Restarted the tracker then try syncing to phone.
5. Restart tracker several times in a row then try syncing to phone.
6. Unlinked the tracker completely and tried to get it to re-sync
7. Let the tracker die completely, then recharge it, then try to sync it.
8. Removing the tracker from previous linked blue tooth devices on my phone and trying to sync again.
None of the above has worked. Can anyone please help?
Best Answer10-24-2020 18:17
10-24-2020 18:17
Which phone do you have and is it on the list of compatible devices? click to see
You read the article for trouble syncing? see if any of this helps - click to read
Best Answer10-25-2020 09:14
10-25-2020 09:14
I have a samsung galaxy 8 and the fitbit versa lite worked with this phone for almost a year and then stopped. I got it last Christmas.
10-25-2020 09:38
10-25-2020 09:38
To directly answer the question. Yes it is on the list of compatible phones and I have looked over the articles and they did not help.
10-25-2020 11:40
10-25-2020 11:40
Mine is doing the same and the time is off as well.....
Best Answer10-25-2020 21:08
10-25-2020 21:08
I was hopeful a moderator would respond but I guess not. I hope you get yours working! I'll be calling them tomorrow to see if I can get any kind of help.
