08-18-2022
08:24
16:56
08-18-2022
08:24
16:56
I charged my versa lite yesterday because the battery was at 4%. I unplugged the charger and left the Fitbit overnight and the battery went down to 0%. This has never happened before. I could go 3 days before I had to charge my battery.
Hi there, @barrypearson695. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa Lite. I understand where your concern is coming from.
As you may know, your Versa Lite battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Also, please make sure you're properly charging your Fitbit device. For more information, see How do I charge my Fitbit device?
Hope that helps.
Hope that helps.
Hi there, @correenp. Thanks for stopping by in the Community Forums. @PamGray89 Welcome on board!
To better assist you, please make sure you've followed all tips and recommendations provided in this help article Can I extend my Fitbit device's battery life?
Keep an eye on your Fitbit devices' behavior and let me know if the issue persists.
Best AnswerI have been having the same issues. I have done the factory resets and it seemed to work better for a bit. Now fully charged in the morning and by end of day by fitbit is fully uncharged. I do not have any apps or special clock faces.
