11-26-2020
12:44
12:50
11-26-2020
12:44
12:50
I’ve got a versa lite, purchased in May this year. It’s been great until the last week, where the battery is barely lasting 24 hours.
Shouldn’t need to charge it every day.
Anyone else had this?
Hi there @katduncs, thanks for stopping by in the Community Forums. Thanks for the details provided in your post and for the screenshot attached, I understand where your concern is coming from. I'll be glad to help you.
As you may know, your Versa Lite battery should last up to 4 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or animated clock faces. While this doesn't mean that you shouldn't use them, please take into into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Let me know how it goes.
Thanks for the reply. I have never changed the clock face, I just checked and it’s the standard Fitbit one. I don’t use GPS or Spotify through it either. Literally just wear it and track my gym sessions. That’s all.
Cheers
Best AnswerIt’s still having the same issues. I rang the place I bough it and they told me to make sure app was updated version and that’s it, which it is.
Any solution?
