09-05-2021
11:58
04:43
09-05-2021
11:58
04:43
The battery on my versa lite is kaput and will not hold a charge, this is after 20 months of use,I get emails from fitbit telling me my battery is low and to charge it, but due to the poor quality of this battery it is only fit for the trashcan now, will never ever consider buying another fitbit, my friend has a cheap tracker with a changeable button battery that is 2 years old and is far better than a fitbit will ever be.
Best Answer09-05-2021 21:41
09-05-2021 21:41
There is a known issue where the battery of many watches drains quickly.
The good news is in most cases this is not a watch problem but an issue with the Fitbit App and/or firmware update.
To verify this, try syncing your watch, then turn off the phone's Bluetooth, Shutdown the watch, wait 10 seconds then place it on the charger for 2 hours, till fully charged and see how long it lasts.
If you notice much better battery usage it will confirm the Fitbit App fault.
09-05-2021 15:58
09-05-2021 15:58
Same problem here.
I am looking for help on this site. Not easy.
09-05-2021 21:41
