06-26-2020
23:40
05:26
06-26-2020
23:40
05:26
my screen turn black on my fitbit versa 2. They battery is fully charged , but i can feel my watch vibrate when i receive the notifications . I just cant view anything .. anyone tht can help thank you
Moderator Edit: Clarified subject & formatting
Best Answer06-27-2020 02:46 - edited 06-27-2020 02:46
Hi @Taverac Try restarting the Versa several times. If that doesnt help then try a Factory Reset and set your Versa 2 up again. If that also doesnt help you then you will need to contact Customer Support.
BUTTON FACTORY RESET FOR VERSA 2 AND VERSA LITE
Hold the back button for about 8 seconds.
When the Fitbit logo disappears: Release the button briefly (for less than 2 seconds).
Hold the button again until you feel a second, longer vibration, which indicates the factory reset.
Helen | Western Australia
Best Answer06-28-2020 19:10
06-28-2020 19:10
Hi i tried doing the reset but still my screen is black 😥 my fitbit is less than one year was working properly and this happened
Best Answer06-29-2020 00:31
06-29-2020 00:31
Then contact Support. The link is in my post above.
Best Answer06-29-2020 05:28 - edited 04-28-2024 07:14
Hi there @Taverac, welcome to the Community Forums. Thanks for the details provided in your post about your watch's behavior and for taking the time to follow @NellyG's recommendations.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
Best Answer06-29-2020 22:35
06-29-2020 22:35
Thank you for the support
