04-05-2021
14:24
13:06
04-05-2021
14:24
13:06
So my versa lite is vibrating when I get notifications but nothing is coming on the screen. I tried to reset it and it just flashed blue and green streaks across the screen. I can get the backlight to come in but no information besides a black screen
Best Answer04-09-2021 13:09 - edited 04-09-2021 13:10
Hi there, @Amgimlin_520. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out.
According to your post, it seems like your Versa Lite is still syncing. That being the case, please try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
By the way, I've moved your post to the Other Versa Smartwatches board for organization purposes.
Hope that helps.
Best Answer04-09-2021 14:57
04-09-2021 14:57
Best Answer04-09-2021 15:47
04-09-2021 15:47
This happened with my versa lite today, too! One minute it was working, and then all of a sudden the screen went blurry and now it’s blank.
Best Answer04-10-2021 04:05 - edited 04-26-2024 08:35
@Amgimlin_520 I appreciate you had followed the tips and recommendations provided above. At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected. We hope your issue is solved soon.
Hi, @Marcia_914. Welcome on board. Please restart your Versa Lite as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face. Hope that does the trick for you.
04-10-2021 11:56
04-10-2021 11:56
Neither of those suggestions worked.
04-12-2021 03:57 - edited 10-10-2023 12:06
@Marcia_914 Thanks for following the steps I suggested above. I understand how disappointing this can be.
